bmxarmy »
https://forums.nicoclub.com/bmxarmy-u170312.html
Thu Mar 08, 2012 11:23 am
Hello again,
As I am about to do a rebuild on my rb25 I have a couple of questions as to how the variable cam timing is supposed to work. My rb25 is running on megasquirt 2 and when I originally got it running last summer I just left the vct un hooked and ran it with out. First question is how does it work? Haha does the stock ecu just switch a ground with 12v being on one side of the solenoid? Or is it more like an iac valve with pwm for control? I am hoping it is simple like it just opens or closes an oil passage at a certain rpm. If this is the case then I can wire my megasquirt to close a relay at whatever rpm I want. That being said, at what rpm does the stock vct enable?
Lastly is there going to be any gain in doing all this or should I just leave the vct out of the system?
Thanks in advance
Nolan
