Andrew85cm »
https://forums.nicoclub.com/andrew85cm-u11573.html
Sat Mar 26, 2005 1:34 pm
Carbon canister. It connects to it. I would just plug them but you need the it to pass inspection if you are worried about that. Both vac lines go to the top of that canister and the bottom nipple goes to a nipple that is on the driver's side frame rail. The other nipple on top of the canister goes to the hardline that is on the driver's side frame rail.~ANDREW~
