RB25 turbo wastegate.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
ok i was wondering when i turn my boost controller off and let the wastegate regulate boost it shouldnt hurt anything right?I didnt know if it would hurt the engine know that it has a boost controller wired in but its not serving a purpose untill i turn it back on so its just passing through the solinoid.thanks
Cjmartz2k
Car: Hunting for a '89 GTR now
I can't see how it would hurt it. You are talking about an external wastegate, right? It should just boost the minimum amount for whatever spring you have all the time.
leesredgt
all i have is the stock rb25det setup i havent changed anything.i guess really my question is since its turned off will it spike above what it can handle thus damaging the turbo or will it max out at 7psi or will it do what ever?i just have it ran from a vac source to the actuator.thanks
Cjmartz2k
It'll just boost stock like that. Make sure it is hooked up to vacuum though, or it'll boost to the sky.
jrd450r
Car: 1990 RB25DET S13
I have my waste gate line run to my intake manifold and itll hold at about 12psi. I thought it should be like 5-7 but its defiantly higher than that. It runs good like that though.
leesredgt
okay thats good b/c thats were i got mine running from.
HPF Chrisk
Car: 240sx
I have mine running from a i/c pipe and i am only running 5.5 you should be fine running it off just the wastegate accuator
