rb25 turbo on rb20, upgrade?
black240jl
Car: black 240sx
i want to get a turbo that i can run about 14-18psi on without messing up, i heard the rb25 turbo is an upgrade for the rb20, i also hear there not much better, my friend has an rb25 turbo rebuild with a differnt turbine, to make it spool faster and he wants 500 bucks usd, and i was wondering if it was worth it or should i get a t3 garrett or somethnig, let me know thanks alot
apollas
Car: rb20 type-m
500 for a rb25 turbo? i think thats alot for just an rb20 upgrade. i think the 25 wont boost that much more than the 20 just that the 25 has better flow than the 20 due to the 20's ceramic wheel. i think thats it for the 25 but i may be wrong though (get a 2nd opinion)
but, imo, with that 500 just save for a bigger turbo
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Depends on what you want. If you already have a running 20 and want it as a 'drop-in' replacement, it might work.
Or you could spend an extra $100-150 and get a new genuine T3-T04e... But you would have to modify your DP, check your flanges, etc. which increases the price.
The choice is yours.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I'd go with the T3/T4E a little more work for a superior turbo.
Joe
apollas wrote:500 for a rb25 turbo? i think thats alot for just an rb20 upgrade. i think the 25 wont boost that much more than the 20 just that the 25 has better flow than the 20 due to the 20's ceramic wheel. i think thats it for the 25 but i may be wrong though (get a 2nd opinion)
the 25 also has a ceramic exhaust wheel and is prone to exploding above 13psi.
you can almost get a brand new turbo for $500. just save and get a decent t3/4.
StricNyne
yeah, i would only get the 25 if lets say u needed car up in a bind, or yeour stocker was blown and u had no money, cause 500 is half of the price of a gt28rs which i think will bolt up and is BRAND new and a better turbo
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
You can get RB25 turbos from $225 - $300. For $500 I'll just get a bigger turbo.
apollas
Car: rb20 type-m
If you dont want to go through the hassle of modifications get a turbo from HKS, there RB turbos are direct bolt ons
l0nestar
2004 Toyota Altezza
black240j wrote:l my friend has an rb25 turbo rebuild with a different turbine, to make it spool faster and he wants 500 bucks usd, and i was wondering if it was worth it or should i get a t3 Garrett or something, let me know thanks alot
Did, whoever rebuilt that turbo, replace the ceramic exhaust wheel with one made from steel?
HKS gear is hella pricey.
black240jl
Car: black 240sx
he said its steel, and its set up to boost up to 20psi and to make 400 hp?
Joe
black240jl wrote:he said its steel, and its set up to boost up to 20psi and to make 400 hp?
unless its a modified rb25 turbo, he is an idiot
black240jl
Car: black 240sx
it is a modified one, full redone, he has 500 into it and he wants 500 back out.., he has an sr20 and was gonna use it as an upgrade, hes running 14psi on his car now, im thinking about snatching it up, hasnt been used yet still brand new
Carl H
a highflowed stock turbo?bleh.i would pass and just get a t3/t4 57 trim for that kind of coin.
black240jl
Car: black 240sx
i was thiking about getting an aftermarket, but i ca prolly get this for 400 and i only want to make like 300whp or 350, it will bolt right up, and spool quick, i think i might go for it, if.when i do i will keep updated.
apollas
Car: rb20 type-m
black240jl wrote:it is a modified one, full redone, he has 500 into it and he wants 500 back out.., he has an sr20 and was gonna use it as an upgrade, hes running 14psi on his car now, im thinking about snatching it up, hasnt been used yet still brand new
he spent 500 on modifying a rb25 turbo? wow..if you think about it he is probably selling it to you and using that 500 you gave him to buya better turbo for himself imo
craz4240
Car: 1995 240sx w/rb20det
I have a custom built rb25 turbo,built to gt2871r specs...it was a 700$ upgrade at the time.Myself I am gonna be upgrading and selling this turbo.....it flows great,bolts right up and made a huge differene and has seen 18psi.Running it this summer and will get some numbers up...then on to bigger things.
amiyama
Ehh... in Thailand we can buy used Rb 25 Turbo (Ball Bearing) about 115 USD. Make sure whether it's white or black turbine ( i heard black is much better)
The most fav. modification combo for RB-20s here is Thailand are;
- Replace to Rb 25 Turbo Ball Bearing (Black turbine)- HKS Super flow air filter - 3" Exhaust pipe- Modified ROM - 4.3 LSD. - Nismo Clutch
All above are hooked up mostly in Cefiro A31
And I heard that it runs mid 13 sec for 1/4 mil.
Some shop here in Thailand can generate 430 hp. for RB-20 and of course, they changed the pistol and everything
If there are any question, we warmly welcome y'all at http://www.cefiro-thailand.com
metal maverick
Car: 1991 240sx hatch, rb20det 230 at the wheels (r.i.p.) 1990 240sx hatch, hp to be announced
this is a link to a forum on skylines downunder the australian skyline page. it has a few dyno sheet results for some rb20s that have the 25 turbo, but careful not all of them are this swap there is a t3/t4 and othersalso got you a kw to hp converter
http://www.skylinesaustralia.c....html
http://www.mr2ownersclub.com/converter.htm
also right here a guy puts down the specs for the 20 and the 25 turbo, and declares around a possible 50hp top end limit gain on the 25 (300hp)compared to the 20 (250 max) of course everybody's engine will respond differently, 2 rb20s with the swap may have very different power gains.
http://www.skylinesdownunder.c...38694
this is most likely what i will be doing next on my rb20i'll let you know in 2-3 months lol
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
RB25 is a good turbo for response/power on a budget... I'd recommend it as long as you can pick one up for 200 or less. I have a 20 and a 25 at my house and will hopefully dyno both soon... if I can ever finish my renov stuff on my house (only taken me 1.5yrs so far but 2 full bath and 100% new floor is a lot of work) I will get some dyno numbers for both. I'm not running a cat though and I think most of the cars on SA etc are... so keep that in mind.
neonbomb
If you have a hard copy of the rebuild and dyno graph of it being used, then 500 bucks would be worth it if youre looking for an easy upgrade.
drftup32
hi.. to start of mate these guys are talking a load of s***, first thing do not buy a t3/t4 they are s***. u would be a hell of alot better using a rb25det turbo but u must buy the correct 1,(45v4)or(45v3) as these are both factory steel internals, 45v2 and any other 1s u will find are ceramic shaft, and therefor these will snap if u ever use a top mount manifold with your turbo as u have to rotate your intake housing.. if to buy a 25det turbo make sure it is 45v4 as i stated before, if u buy a t3/t4 expect to be hiting boost at 4g ... pathetic, on my rb20de+t i have a rb25det turbo and it is crazy it does ezy third gear stand stills and holds drifts amazingly, al i have done is put a rb20det wastgate actuator on the turbo so it runs a nice 10 pound boost, only other modification is a walbro fuel pump, 2 and 3 quarter exhaust and the correct tune for a plus t, and is incredibly reliable, it goes so well the injectors are maxd out and it owes me the minimal dollar, cheers
Yellow4g63
Scotty712
Car: Rb20 s13 coupe
drftup32 wrote:hi.. to start of mate these guys are talking a load of s***, first thing do not buy a t3/t4 they are s***. u would be a hell of alot better using a rb25det turbo but u must buy the correct 1,(45v4)or(45v3) as these are both factory steel internals, 45v2 and any other 1s u will find are ceramic shaft, and therefor these will snap if u ever use a top mount manifold with your turbo as u have to rotate your intake housing.. if to buy a 25det turbo make sure it is 45v4 as i stated before, if u buy a t3/t4 expect to be hiting boost at 4g ... pathetic, on my rb20de+t i have a rb25det turbo and it is crazy it does ezy third gear stand stills and holds drifts amazingly, al i have done is put a rb20det wastgate actuator on the turbo so it runs a nice 10 pound boost, only other modification is a walbro fuel pump, 2 and 3 quarter exhaust and the correct tune for a plus t, and is incredibly reliable, it goes so well the injectors are maxd out and it owes me the minimal dollar, cheers
Um no^^^^^ ALL RB 25 turbos have ceramic exhaust wheels man smh, they have different material front compressor wheels. All max of 14 psi. Ball bearing doesn't mean steel wheels lol
