10-4 i did this "mod" a while back do a search i posed about it.Kamin wrote:bolt on as far as i know.
Rb20 wastegate will out you at 10ish psi when the rb25 one will put you at 7 i think, so use the rb20 one thats what i did.blues14 wrote:should i use the rb25 actuator, or switch to the rb20 one? i will also do some searching.......
Just coolant, it will pretty much leak till you plug the line, dont pay a shop its easy just remove and replace job.blues14 wrote:did you do it yourself? is it messy?(coolant/oil) I am pretty handy, but all i have is hand tools. I am not sure how much a shop would charge to install this, but if they break something, at least THEY have to fix it.
zerothread?id=133496Vkoslak wrote:So if you use the rb25det turbo, and slap the rb20det actuator to run the 10psi, do you need to change anything else? (injectors, engine management)
It spools pretty much the same im just very anal, i listen to my engine all the time and small sounds annoy me and i spend all night tracing them down, put it this way if you can get the turbo for 100 or under go for it, if not than dont bother.Vkoslak wrote:Thanks for pointing that out.
After reading your post about the later spooling and not that much power increase, I say why bother. I want quick spooling!
