RB25 turbo, is it worth it for mild build?
BlackZenki82
Car: 1991 Nissan Skyline GTR
so whats up guys, i just had an opprotunity to trade some old wheels of mine for a stock T3 turbo off an RB25.... i've done some reasearch, and came up with a few things.... first, it MIGHT be a ball bearing turbo but it also has ceramic impellers that will break under heavy boost.... i have no plans of running heavy boost... maybe 8-10 at best, and roumer has it they fly apart at around 13-14... so i should be good there... here's some of the specs i've found on it...
RB25 turbo specs -
25t comp wheel 48x66comp cover .60 a/rturbine wheel 51x43.5 a/r turbine hsgaround 300hp
thats about all i know.... i don't know much about turbo charging or anything, but i know i'm goals are around 250WHP... and i've read in the KA turbo bible that a T3 is the way to go for this.... just a question guys... the guy wants to trade this weekend for my motegi MR7 17x7 +40 with 40% tread.....so i figured i'd slowly start pieceing my turbo kit together... it also will be coming with a elbow and BOV (ebay BOV.. will replace with a HKS ssqv later on)..... i figure this might be a worthy investment in the first parts of my KA-T build.... and i love how the turbo has "Nissan" across the front, for that OE look... well let me know your thoughts and give me some suggestions... thanks guys, just wanting to know if it's on okay turbo to work with.... see i just don't know about these things.... and the guys has no history on it, says there's minimal to no shaft play (i'm assuming thats the inner turbine assembly) and it's not in bad shape.... so i dunno HALP!!!!!
480sx
Car: 1996 Pearl White 240sx
That turbos fine for your mild build, actually its quite well suited for it. Just dont push more than 14 psi of boost with it or the ceramic blades are a disaster waiting to happen.
Dude.. You want to trade at least 400 dollars worth of rims + with decent tires for a 150 dollar turbo and some random junk? Those are actually not bad looking rims either. Very one sided trade IMO.
BlackZenki82
i can't sell the wheels, they've been for sale for almost three months... and i'm only asking 300 for em... so a turbo, yeah, just to get the wheels, out but it's not too late to back out of the trade... it hasn't happened yet... i've asked for advice on several forums and hadn't gotten much back....
but you think it's one sided??
NateDogg
I'd ask him for a c note.
Otherwise, ya the turbo should be good for around 250whp at 10psi.
neverlift
be carefull when clocking that ****ing pos, I was taking the one I got today apart and the damn turbine wheel broke personally I will never try an rb turbo again, even though the compressor wheel is larger/better trim. and those go for 80 bux around here, my dood probably has another if you want... email if you want me to find out...
480sx
Yea id just pass on that deal man, you can spend your money in much better ways.
z.hunter1
Car: '92 240SX
Turbo works for your setup, but the trade seems alittle one sided
BlackZenki82
z.hunter1 wrote:Turbo works for your setup, but the trade seems alittle one sided
yeah i took a pass on the trade.... but it's the turbo i want, selling and trading a bunch of other stuffs for the set up though, i want that turbo bad... i think it'll be perfect for what i'm going after...
abc123omg
Car: '93 240sx KA-T
keep ur rims, you can pick up an sr t25 for 100 give or take a few.
WDRacing
Not like it needs to be repeated...
Good turbo, bad trade.
Also...if you can't clock the turbo...don't blame the turbo
I've takin plenty of RB turbo's apart and put them back together...actually if your smart, you'll take the cartridge of one and use the compressor of say a TO4E and make your own BB turbo
WD
neverlift
seriously IDK I was using under 1/4 turns to jack the thing apart. Checking after every turn to see if the wheel was bound, wasnt, went another 1/8 and crack.... it must just be me...
WDRacing
You do have that title for a reason homie
neverlift
yeah I hear ya I have some random shyt happen too often if someone would buy my ****ing afm z32 for 75 shipped I could get another turbo or 2 for a hundred. but my sales are not going well enough atm.
480sx
75 for a z32 maf? You tested it? Hows the case/screens on it? Im interested, send me an email bud. [email protected]
neverlift
emailed
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
BlackZenki82 wrote:
That is _not_ a stock 25 turbo.
This is.
Gallery:Stock Turbo
Red93coupe
Car: 1993 CA powered Coupe-sold 1996 Maxima 5spd all black, 1992 300zx all black 2+2 soon to be TT
This is.
Gallery:Stock Turbo
That top turbo looks to me like a stock z31 turbo, from what I can remember its still a t3.......Check this out....zerothread?id=390839
