RB25 Turbo extension????
drft24d
anyone seen these? I wonder if they will fit a s14 with an rb anyone know for sure Im thinking about getting one..
http://cgi.ebay.com/ebaymotors...33742
Bluefire
I highly doubt it will clear the steering column
-Bluefire
drft24d
I saw a 97 rb equiped 240 that had an HKS extension on it,, i wouldnt think that would fit either.
Modified by drft24d at 6:43 AM 1/4/2005
Imissmyturbo
Car: Car's, Turbo's, sking
I was going to say the same thing since the picture shows it installed on a Skyline. But I bet if it's close like the stock housing you could dent it in to clear.
drft24d
Im using the mskinney mounts if that makes any difference
RbKouki
I would like to know too, I just bought one, and am using the Mckinney mounts also.
420_240
Mckinney mounts don't make any difference with the s14... i'm using their mounts and have their "down pipe"... the down pipe wouldn't match up to the turbo elbow... and since the steering shaft was rubbing on the turbo elbow, i'm just having one fabricated that clears the shaft and matches to that dammn down pipe
drft24d
damn the steering shaft sits that close to the outlet???
420_240
Yeah it's a real PITA... there are several other s14's that had the same problem
drft24d
I wonder how that one guy got that HKS outlet to fit his S14..
RbKouki
oK you can see the steering shaft right next to the housing on the exhaust side, judging by this picture you should have no problem with clearance using that outlet.
