DOHC20sr wrote:ive been searching the archives, and cant find anything yet. im about to do a rear main seal on an rb25 in a s13 chassis. the question is, can the transmission be pulled with out pulling the motor too? mckinney mounts are used also
hey vk you have drop the trans mount, unbolt the engine mounts, with the car on the jacks lift the front of the engine with a cherry picker to get the engine angle high enough so you can get a long extension with a swivel socket and you might have to dent the firewall more with a prybar and the transmission should come out, ive done this 4 times on my car so it is possible.
