RB25 transmission: pull to push conversion
Iknowthefuture
Car: 2000 Pontiac Trans Am
I haven't found a definite answer on this topic and want to set the record straight. I have a neo transmission and want to convert it to push to save cash by using a 300zx clutch.
I found a post by Reignman way back. can anyone verify that this is all that I need to do it?
"Well after searching on the web and other forums I found that a R34 RB25 transmission can be converted to push type for a couple hundred dollars with the parts below: "
Part - Nissan Part #
Front Cover - 32110-05U11
Front Cover Gasket - 32112-05U11
Throwout Bearing Sleeve - 30502-14601
Clutch Release Fork - 30531-01S00
Pivot Spring - 30534-E9000
Bearing Retaining Spring - 30514-14600
My understanding is that buying these parts, it will be a direct installation and no modification needed except for drilling and tapping for the slave cylinder.
Carl H
Iknowthefuture
those parts listed, aren't they not z32 trans parts? I would rather buy the rb one's which I've heard already have the pivot ball installed on the front cover verses drilling and tapping.
Iknowthefuture
From this site (http://www.intecracing.com/ATSCarbonClutchPriceList.htm)
32110-05U11 front cover ASSY, 32112-05U11 gasket front cover, 30531-01S00 release fork, 30534-E9000 spring (for pivot), 30514-14600 spring (for sleeve), 30502-14601 clutch bearing, 30501-S0200 bearing sleeve(18mm), 30542-31G10 cover dust, 30620-21U01 slave cylinder ASSY, 30855-05U00 hose.
Carl H
go ahead and spend silly money on rb specific parts or just get the z32 gear which is the same crap...just drilled differently.
Iknowthefuture
Does anyone have the part numbers to buy the z32 parts from a part store?
74260zt
Car: rb26powered early 74 260z car
I've been looking for a neo 5 spd for sale. I have a perfect cond R33 push type rb25det 5 spd I'll trade you. Let me know if your interested.
joel
Carl H
you're kidding right?
dealer only parts there!
Iknowthefuture wrote:Does anyone have the part numbers to buy the z32 parts from a part store?
Iknowthefuture
Carl H wrote:you're kidding right?
Correction. Parts department... and exactly what parts are needed.
Carl H
its posted in the link...
