Shifter pops out of 3rd gear when i let off the gas... I think the check ball/spring is screwyS14-NEO wrote:that will pretty darn close if ask me.what are you trying to find.?
go to page 37 of http://www.nicoclub.com/FSM/pa...t.pdfCjmartz2k wrote:I've exploded a few RB25 trannies, but I never made a diagram. Are you just trying to find out where the ball and spring is? If you find a pic of the driver's side of the transmission (actually passenger side for a USDM car) I'll circle it for ya.
Yeah i did everything right, bored the hole out some cuz it was catching... But no dice, car still pops out of third.Cjmartz2k wrote:Yeup, that's what I'm talking about in figure SMT366A. Top pic---and they aren't kiddinng about that little ball falling down into the transmission if you take it out wrong. That s*** sucks.
tried today w/ boots off does the same s***... I added a smaller longer spring in with the ball check spring to add a bit more pressure behind the ballbearing.. yea... It might just be a gear or shifter fork or something.. gay.Cjmartz2k wrote:Hmm, if that ball was indeed catching, that should have been your problem. I wonder if because the ball was catching, the spring got squished or something? If that thing is pushing into the "bump" for it on the shifter rail now because you fixed it, something HAS to be pulling it out. I know you checked it already, but try taking all of the shifter boots off and driving it around the block like that, just to isolate the problem.
Also, try the ball/spring thingy underneath the plate by the shifter too. Easy to get to, so it can't hurt to try.
