l0nestar wrote:You need to search man. There have been several threads about trans fluid. Everything internally should be nearly identical to a VG30DE (non turbo). With the exception of the input shaft and maybe something else. Andy (Booztd3) did a good write-up on it. It is long and detailed and well worth it.
I apologize, I must be using the wrong keywords in the searches or something.. I searched and came up with just a few results basically asking if the spec should be GL-4 or GL-5, but nothing specifically spelling out good results for weak syncros. I'll give it another shot with different keywords.
Thanks for the heads up on the Booztd3 post, I'll go find that one now.
