RB25 transmission Swap
bonestocksr20
Car: 1993 240sx w/ sr20det
Well i recently blew my rb20 so im buying a rb25 with an a/t. I am wondering if my 20 transmission will bolt up to the 25 or will i need the 25 bell housing? RB gurus please let me know so i can drive again. ThanksRobert
TSL
Car: Nissan
Bell housing bolt pattern is the same.
Clutch slave cylinder, trans mount, tailshaft and speedo drive are all different.
bonestocksr20
i already have all those parts on the rb20 transmission, so they wont work with the 25?
BoostFab
Car: S13cp, S13fb, S14z
it will work; just bolt up the rb25 motor and wire it up.
transfer the flywheel, clutch over. you need to get a new pilot bushing, sicne the rb25 was auto.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
out put shaft for the drive shaft will be diff tho, good luck w the swap
jdmser
Car: duh
If he had a rb20 in already and is just replacing the engine with a rb25 and reusing the rb20 transmission he can just reuse the drive shaft he had.
bonestocksr20
^ that is what i thought, so all ill need is a pilot bearing?
BoostFab
basically everything from the flywheel back can be reuse.
