Rb25 to S14: Which transmission mount do i use? My JGY mount doesnt work w/...
sepulchralx
Car: 240sx
My jgy mount doesnt line up with the center two 12mm bolts of the r33 transmission mount. Am i supposed to use the old engines automatic transmission mount and ditch the JGY? what the heck
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I'm assuming the JGY's are TopHat mounts. Yes I had to bore so many of the holes wiiiide so I could get the thing to fit. You are better off just getting some box tubing and making one yourself or having one made. Even if you do get it to line up, the transmission will still bounce around because the mount is limp wristed.
RBKIDD
Car: 92' RBsilvia
07' TBSS
make sure you have the engine mounts on right to.i had the same problem with the trans mount bein a pain the butt all bc i had the engine mounts backwards.
