300zx PN: SU4089 does indeed work with no modifications, however, there is a small difference. The trigger wheel alignment in regard to the cas key is different. As seen in the photo, its nearly 180* different. Perhaps the 1* and 120* pins need to be swapped in order to run the same key alignment as the rb25 cas, but since my cam has no key and is broken off, Im able to spin the cas axle to where it needs to be in order for the car to run.
All in all, it was plug and play, just the cas key alignment is different. The car runs great.
New Cas on left, Rb25 cas on right.
