Postby
skyline084 »
https://forums.nicoclub.com/skyline084-u171542.htmlThu Dec 30, 2010 10:19 am
I have an s13 rb25, and I'm getting the code 54, which tells to check signal circuit from A/T control unit to ECU.. Thing is I have a manual trans. Why would it be throwing this code?
Reason I am asking is because all of a sudden started to jump RPMS, backfire, than stall out. It will usually happen now after I've been driving for a while.
Postby
Krazykouki »
https://forums.nicoclub.com/krazykouki-u172082.htmlSun Jan 02, 2011 3:46 am
Not sure what I would do in this case, never come across this problem before. Personally, if I had a 5 speed, I'd ditch the auto ecu for a 5 speed ecu....problem solved instead of doing something ghetto that others might suggest.
Postby
skyline084 »
https://forums.nicoclub.com/skyline084-u171542.htmlMon Jan 03, 2011 12:17 pm
no idea where it's been moved too.. I plan on getting rid of my ecu now. I plan on getting an ems? any suggestions? I plan on keepin my motor stock for a while.. and can't afford anything crazy right now
Postby
Carl H »
https://forums.nicoclub.com/carl-h-u9196.htmlWed Jan 05, 2011 9:10 am
the problem you are describing is more akin to a grounding issue or a bad cas issue rather than an ecu issue.
nissan auto ecus run manual cars just fine...just set base timing a hair higher due to the lack of autologic signal.
ensure you have proper grounds to the engine and all is well wiring wise...also check plug connections as a plug that may appear seated can be loose.
Postby
Joe »
https://forums.nicoclub.com/joe-u4941.htmlWed Jan 05, 2011 5:53 pm
skyline084 wrote:no idea where it's been moved too.. I plan on getting rid of my ecu now. I plan on getting an ems? any suggestions? I plan on keepin my motor stock for a while.. and can't afford anything crazy right now
up at the top of every page on NICO there are what are called breadcrumbs
NICOclub Forums ‹ Nissan Engines ‹ RB20DET / RB25DET / RB26DETT Forum
