RB25 Thermal Transmitter
xxnak219xx
Car: RB25 240sx
Anyone have a clue on where I can get a new RB25 Thermal Transmitter... or by any chance is there any other car that uses a compatible one? The top of mine is cracked off... I don't know how many wires it has and how/where they connect to the transmitter... Is there a way to wire it up/fix it even with the top half missing?Any help is greatly appreciated.Thanks,Kevin
Joe
wtf is a thermal transmitter?
temp sender? lol
Carl H
thermal transmitter is for the gauge cluster temp gauge...just use the ka's TT to make it read right.
xxnak219xx
Car: RB25 240sx
Carl H wrote:thermal transmitter is for the gauge cluster temp gauge...just use the ka's TT to make it read right.
I thought it was the other way around?? There's two sensors... I thought the bigger one was the Coolant Temp Sensor for the gauge cluster and the smaller one is the Thermal Transmitter for the ECU...
Joe
this is why i have never heard that term, nobody knows what it is lol
2 pronged plug = ECU1 pronged plug = gauge cluster
xxnak219xx
Car: RB25 240sx
How
Joe wrote:this is why i have never heard that term, nobody knows what it is lol
How sure are you on that? Not trying to be a d!ck... I'm just making sure... b/c if that's the case then I don't really need to worry if the cluster gauge doesn't work... just as long as the ECU gets the info it needs...
And yea I had no clue what it was until I realized I had two sensors... and one was broken... so I looked it up in the FSM and that's what they called it... Basically just a stupid name for Temp Sensor...
Carl H
thermal transmitter = gauge temp sensorengine coolant temp sensor = as the name implies.
