That looks really cool! I bet that this air/water intercooler setup would be better than the stock side mount for sure, maybe even better than a front mount if youre talking about reducing lag, and pressure loss.float_6969 wrote:The reason that I'm looking to go to the crossover manifold is because I'm considering a liquid/air intercooler and this setup would allow for THE shortest intake tract possible.
This is on an RB, but it is basically what I have in mind;
Those were an 8V head. The mani is different.RS12Turbo wrote:Late '88 S12's came with it like that.......I see them on Ebay every now and then.Check http://www.club-s12.org Someone may have one on there that they're getting rid of
He just wants to use it for packaging with that W/A intercooler.Liquid_Neon wrote:yeah, 87-89 SE twin cam pulsar nx's have that. in fact.. thats the manifold in my pulsar feeding my ca18det. So ur telling me its suposed to be better then the rwd mani? or do u just wanna test that theory?
Not to doubt your experience, but can you expound on your, "That intake manifold is a headache and one should avoid it all costs." statement? I understand the runner difference, and although I wasn't aware of it before, I don't really see a problem with that. Is it just harder to work on? Does it not flow properly? If it's simply an issue of maintenance, then I would be willing to sacrifice that for the added simplicity of my intercooler routing.boost_boy wrote:TMS is right! Though this manifold kinda resembles that of the KN13 pulsar SE or EXA, they are not the same. That turbo intake manifold comes with multiple/individual runners for every port, so you'll have 8 runners extending towards the head. The pulsar's intake manifold is just like the RWD/AWD manifold except the fact that it's throttle body is facing in a different direction. That intake manifold is a headache and one should avoid it all costs.
Dee
It is a manifold with some useful function as each individual intake port gets it's own runner which is nearly equal the diameter of the intake ports. The downside to it is not so much the maintenance, but the fact that it is set-up for a different head. That's right , the head on that engine is different than the head on 1988-1991 CA18DET engines. You can always see for yourself and you'll see just what I'm talking about. It's just different and would pose a problem for you and your modern CA18DET head. I hope that helps a little more.float_6969 wrote:Not to doubt your experience, but can you expound on your, "That intake manifold is a headache and one should avoid it all costs." statement? I understand the runner difference, and although I wasn't aware of it before, I don't really see a problem with that. Is it just harder to work on? Does it not flow properly? If it's simply an issue of maintenance, then I would be willing to sacrifice that for the added simplicity of my intercooler routing.
Duh, then just switch the heads Honda guys do it all the time, haha. Come on Dee I thought you were better than that man.boost_boy wrote:The downside to it is not so much the maintenance, but the fact that it is set-up for a different head. That's right , the head on that engine is different than the head on 1988-1991 CA18DET engines.
It might be the same concept but i doubt its a "bolt in" affair. Most than likely its not and i think he was referring difference in heads, sohc or dohc, and physical shape of the heads. I suppose if it used the CA block and some kind of CA head, theres probably a way but it certainly wont be easy.Sil40sK wrote:Duh, then just switch the heads Honda guys do it all the time, haha. Come on Dee I thought you were better than that man.
