2mm stroke difference actually...Carl H wrote:not much of a stroker, more like an rb26 now...iirc there is a 1mm diffrence stroke between the 2 motors...sounds bout right tho...why not get rb26 bearings, better oiling imho...
why don't you go with 8.5:1 or 9:1 CR....you'll get a more responsive motor instead. with your 87.5mm bore, you 're getting closer to maybe 2.7L stroke.rustbucket wrote:RB26 Wiseco pistons 87.5mm, 8.25:1 comp, 1.181" compression height
