Im running 12psi with a rb25 s2 turbo, with a fmic, 3 inch turbo back with a fart can, Kamin is right i was running 14psi for about a month and it is a waste of time, the turbo looses efficiency, 12 psi is about the best for power, too many worries at 14.Kamin wrote:series 1 or series 2 rb25?
the S1's have notoriously weak turbos (ceramic exhaust wheel, realistically safe to 12-13psi before the exhaust wheel explodes.)
the S2's are safe higher, but are WAY outside of their efficencey range anywhere above 12-13psi. sure you CAN run more, but theres no real reason.
Hmm... That's pretty scary. Are you sure there were no other factors that lead to disintegration?y3llows14 wrote:DO NOT RUN 14PSI...even on a series 2. THis is what happen when ran at 14 psi on my series 2 rb25det.
keep us posted, I'd like to know how much hp you have now and how much hp you have after you get the fmic and manifold.wawazat8402 wrote:Ive been running 12psi for a few weeks on the SMIC. As soon as I turned it up we ran it with a wideband several times and made some slight adjustments with the SAFC. It pulls very smooth now, and Im sure it will only be better next week with the fmic and Greddy intake manifold.
Are you referring to me? If so, I always run a wideband session after making these types of mods to the engine. If it runs to lean and my tuner doesnt think it would be wise to tune an SAFC that far, the parts will come back off til I get AEM.SillyRB wrote:FMIC + 255 + 13-14si + Stock ECU = LEAN
