RB25 Starter Solenoid
gomer23
Car: 1989 Nissan 240sx
Long story short I think I fried my start solenoid on my RB25, I need to now what the replacement part is for it. Thanks.
Imissmyturbo
Car: Car's, Turbo's, sking
If you lived near me I would send you to my local starter/alt rebuilder. Check and see if you have a local rebuilder that could look at it and find a replacement.
Shocker
Car: 89 240sxHB rb26/30
why not give him his number and have him ship his parts to him, and then back again.. sure it will cost a litte, but at least hes gonna know it will work, and not have to wait forever to get one from japan.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
Assuming that the solenoid you are referring to is the black thing with the two wires go to for the starter, then you can just use one off the KA starter. One of the prongs were broke when I got my engine so I just swapped them out and it worked fine. The little plastic shaft that is in the KA one is different than the RB, so just use the one from the RB and you will be fine. Unless you happen to have gorrilla grip like I do, plan on using an impact driver to remove the philips head screws that hold the solenoid on or you will strip the hell out of them.
gomer23
Thanks for the info. But I was messing around again tonight and the whole starter is shot. So now i need to find which starter to replace that with.
skwertle
u
gomer23 wrote:Thanks for the info. But I was messing around again tonight and the whole starter is shot. So now i need to find which starter to replace that with.
did you ever find a another starter? my starter is goin out.
Joe
its not really necessary to bump all the old starter threads. just bump 1 and wait
