bmadd2402 »
https://forums.nicoclub.com/bmadd2402-u23099.html
Tue Jun 17, 2008 7:55 pm
First things first, makesure that hole isnt a boost leak, then check for more boost leaks. then check your ciols for cracks/torn boots. then check your ignitor and coils with a multimeter per the FSM. put the stock ecu back on for troubleshooting purposes. check your MAF voltage, and TPS voltage, check coolant temp sensor, and timing. Did you replace the timing belt? if so, double check the mech timing. then set timing and idle per the fsm. if all that checks out, then it may be rich and retarded. the ecu sees too much air coming (some call this maxing the MAF) into the system, and pulls timing and dumps fuel in to keep the motor from blowing up. Esp with a FMIC, intake and exhaust, and increased boost. This is where the emanae comes in. get it tuned. you will be pleasantly urprised. I struggled with this problem for a long time before I finally broke down and bought an aftermarket ecu and like magic, the problem went away. Get on SAU and search for R & R, or rich and retard.
