RB25 Speed Sensor
roadrunr
Car: 1992 Nissan 240SX Convertible
I am finishing up my wiring for the lower harness of the RB, I cut all the plugs off the KA and put them on the RB, one I can't find the wire colors for, its the speed sensor, the KA uses a yellow with a blue stripe (should be signal) and a yellow with a black stripe. The RB has a blue with a red stripe and a yellow with a purple stripe, anyone know which is the signal on the RB? I can't check the voltage because the engine is still on the ground, and I never could find a wiring diagram that shows it. Both KA and RB are Automatics.
roadrunr
Well I found that the KA yellow with black stripe is power, and if all holds true on the RB then the blue with a red stripe is power, so the KA yellow-black goes to the RB blue-red, and the KA yellow-blue goes to the RB yellow-purple, I guess if it does not work I can always switch it, if I don't blow the sensor hooking it up this way. If anyone can confirm this please let me know, and thanks for looking guy's. RR
fly240
Car: nissan 240sx
hey, did you get it to work....?. i'm wondering if you got the reverse light to work too.....i'm having trouble with the reverse light...need help....
