sparkplugs.com »
https://forums.nicoclub.com/sparkplugs-com-u23266.html
Fri Dec 18, 2009 11:39 am
hope this clears up a few things:
higher number, colder the plug on denso and ngk. american plugs are opposite. only reason to change heat range is if you've changed engine conditions. mods that added horsepower are the largest cause to necessitate a heat range change. every 75-100hp added, go one step colder.
regarding the plug listings...none of the data is created by sparkplugs.com. All data comes direct from the manufacturer. Therefore, we can only list the stock plugs for a vehicle, we can't list the colder plugs, etc. For US vehicles, this is updated every 6-12 months. The non-US lookup is something we created by special request from you guys. Going back about 5 years ago, we stole NGK Australia's app data to give that to you guys.
Using a plug with a different design from your stock plug type is dangerous (not talking about using iridum instead of platinum, or a colder plug when its necessitated, solely referring to if the plug configuration is different, which is obvious, as a general rule, if the part number before the heat range is different) and can cause engine damage. If anyone ever has any questions on if a plug will work for their engine/setup, or wants to know about possible problems, feel free to ask, that's what we're here for!
