RB25 Solid Lifter Conversion
Chaos the Xile
Car: 1974 Datsun 260Z
I'm currently rebuilding my RB25 head, wanting to use solid lifters instead of hydrolic since i'll be running Tomei Procams. Instead of buying a set of Tomei solid lifters could the RB26 stock solid lifters be used without any modification to the head?
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
We wish it was that simple, unfortunately it would involve a lot more since the Rb26 valves are different lengths compared to rb25.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
i think that the 25 lifters are a bit smaller then the 26
Chaos the Xile
damn! wel i guess its the tomei lifters then let me know if you find em cheaper than $490
eh?
The diameter is the same per the fsm. Custom shims maybe needed? Don't know, you can try buying a RB26 lifter or two and check out the clearances yourself. Either way you would need new shims. I'd rather buy a whole RB26 head and be done with it.
Chaos the Xile
well eh? if you find me a complete rb26 head i'll buy it... but a shop by my house has a couple of rb26's in stock maybe i'll stop by and see if we can frankenstein some stuff see what works... maybe it'll lead to a pretty interesting walk thru, who knows.
Cjmartz2k
Car: Hunting for a '89 GTR now
I can find n/a RB20 and 25 neo's over here with out to much trouble. Would they have solid lifters you could stick into a turbo 25 head?
eh?
Chaos the Xile wrote:well eh? if you find me a complete rb26 head i'll buy it... but a shop by my house has a couple of rb26's in stock maybe i'll stop by and see if we can frankenstein some stuff see what works... maybe it'll lead to a pretty interesting walk thru, who knows.
http://forums.fresh alloy.com/showthread.php?t=186548
Older thread but no replies..
Chaos the Xile
you work fast!
Cjmartz2k
I'm picking up that neo head today after work. I can measure something if you want.
Chaos the Xile
that would be great i found a NEO head on Zilvia, my question is wht the NEO head will I need the R34 GT-T harness to get that head to work with my S1 RB25???
