d356bud wrote:did u remove the air regulator on the Q45 tb?
Yeah, If you're referring to the cold start coolant solenoid.
I had a tech friend set it on compression stroke, then tested. After the manifold.. i did it on my hot pipe from turbo outlet. I had Air regulated at 22 psi coming in, after it charged.. i watched the gauge to see how fast it was going down.
on the Q45, i adjusted 3 things.
1. Removed Cold start coolant solenoid
2. There's a tiny little screw with a lock nut on the bottom (if installed on RB25) that the butterfly level bumps to keep it slightly cracked or can be adjusted so its neutral position is completely closed. I adjusted it to a slight crack after i got my car running bc i removed my AAC.
3. Adjusted the TPS Sensor back a little bit until it read .4 v at new "closed" position.
Iam not sure why this all came up, but i do have a feeling it has to do with the fact i have a series II rb25, i removed the TCS harness on stock tb, and only used TPS. So i guess there is no "idle verification signal?"
