FinkenS14 »
https://forums.nicoclub.com/finkens14-u122268.html
Fri May 21, 2010 5:36 pm
Hey guys I got a issue (kinda) with my RB25 and its not really bothering me, just making me wonder.
Its a bone stock 25, stock turbo at 12psi, FMIC, Yamamoto tuned ECU (came with the motor set), and Im tuning it with an SAFC.
Since I live in Colorado, and the air is much thinner, and it was a tuned ECU, even at 12psi on the stock tune, no SAFC my AFR's were 9.9-10.2 at wide open.
So I got an SAFC2 to fix the problem.
I got a good base tune on it, 11.5 AFR's at wide open using my Innovate wideband. And it hauled wonderfully. Much better driveability around town aswell.
Well every now and then, my car will go rich again. From the SAFC tuned 11.5 to about 10.8, and the car feels a little sluggish.
No SAFC wires are loose, they are all soldered and heat shrinked, I converted the harness on my own, from what I know no breaks in the wiring, everything is soldered and heat shrinked.
What could be the issue?
One of my buddies said its the SAFC causing my issues and that since the ECU isnt reading air temp anymore, or something along those lines, the cars AFR's will change on a day to day basis.
I have kinda noticed this.
On cold night the car will be perfect, 11.5-11.8, no knock, pulls smooth and strong.
But on hotter days it richens up and has the sluggish issue.
Any thoughts?
