rb25 s2 temperature sensor i need a new one!!!!
rb25detilovit
Car: rb25det s14 stock turbo 11psi
does anyone know if there is a sensor that is interchangable for the ecu temp sensor mine started leaking and not at the washer through the actual sensor. just noticedd this and now i cant seem to find anyone who put up a straight answer please help me out and i dont need the temp sensor for the gauge its the other one.
Cjmartz2k
Car: Hunting for a '89 GTR now
Series I = series II, so what do guys stateside use to replace those?
rb25detilovit
z32tt? heard some talk of 98 ka sensors working and answer would be real sweet at this point and one that i can trust would be even better.
imotion s14
Car: 1997 240SX
I used the one off my kouki s14. I still have the sensor off my RB if you want it.. lmk [email protected]
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Not sure if this is of any use but i used a 1993 300zx NA one for my rb20.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
1996 Maxima -all vq30de models work. 100% sure.
rb25detilovit
about that maxima sensor are you running one or what? have you seen a rb25 with one installed if so you are the man and im getting one tomorrow ?
Fibre guy
Running one. Plastic color on the clip part varies from manufacturer to manufacturer, so don't worry if the color isn't the same as the old one.Also, many other people run this same one with no problem at all.
rb25detilovit
thanks fibre guy i needed that. also your coil covers......amazing im gonna have to look into molding in what not that looks like fun. Still making the vented ones for the 25 if so i would most definently purchase one.
Fibre guy
Actually... I'm drawing up the new vent design onto sheet metal to cut out right now.
rb25detilovit
very cool.....ill take one when you have a finished product . when do you think theyll be done. and by the way bought the sensor everything works fine thanks man
Fibre guy
I have a link to the cover build in my sig.Just keep an eye on it because I'm trying to keep it as up to date as possible.
