Terrh »
https://forums.nicoclub.com/terrh-u94768.html
Sat Oct 10, 2009 8:19 am
Some backstory:
A friend of mine brought me his S14 to do some work to. Long story short it ended up having a blown motor in it. He bought it pre swapped with what I believe to be a series 1 RB25. (TPS has a connector and a short sub harness)
He asked me to put a new motor in, I agreed, found him a motor (S2 RB25 I believe, TPS has 2 plugs but no wires coming off)
I put it in, hooked up all the wiring (had to swap coils and coil harnesses because they were different, and the knock harness because it was damaged) and now it's not starting.
I have spark, it has compression - but I don't hear the injectors clicking or smell fuel out the spark plug holes if I crank it with them out.
I checked the ECU codes and got code 34 - knock sensor - one of the wires to one was loose, but I fixed that.
How can I figure out what's wrong here and get it running?
Are S2 injectors or wiring incompatible with an S1 ecu/harness? All the wires look like they're in the same places but are different colors so idk.
Thanks in advance for any help you can provide. I'm pulling my hair out here, I want this thing to work so I can get it outta my garage!
