rb25 running poorly need input
sleepin240
ok so after getting my guages wired up and discovering my car is not throwing any codes im wigging out...
my idle is poor however sometimes it idles good...
when i take it down the road its like it spools then its like i run into a wall when press the gas all the way down...
it does it in every gear it spools up then just fizzles off... i know your thinking boost leak ive had everything triple checked no boost leak
so what could it be.....?
on another note i would like to add that i tried unplugging the mafs to make a check light go off and it didnt... is this normal
JonPowell
Car: Cars, Music, My family
Timing man, check your timing....unplugging the MAF's SHOULD make the CEL come on, IF you wired it up....
Ususally a boost leak will cause it to pop and spit, what you explain sounds like its not firing at the right time...
sleepin240
i sure did white with a red stripe its wired.... hard wired it to the cluster
eh?
Does runs fine under part trottle but hits a wall at full throttle @~2500rpm?
Joe
a "wall" is a problem. triple check all your vacuum routing. if your wastegate line isnt hooked up properly your maf will be maxing and causing a problem like you described.
also, it sounds like the engline light it wired wrong..
sleepin240
eh? sounds like you just nailed it thats about right part throttle is great but under full throttle around 2500 its dead
sleepin240
Kamin wrote:a "wall" is a problem. triple check all your vacuum routing. if your wastegate line isnt hooked up properly your maf will be maxing and causing a problem like you described.
its all according to factory i labeled everyline as i took it out of the clip the only thing different is the missing charcoal box
JonPowell
that wouldnt effect your drivability
leroy0053
Car: guitars and cars
replace mass air flow sensor. if its fine then u about 2500-3000 rpm then your car starts jerkin, definitely maf.
leroy0053
oh nevermind didnt read where it said part throttle is good my bad man:(
eh?
You have a tps problem. Check your idle voltages at the sensor.
sleepin240
ok update made the ecu go into check mode... returned a 55
unplugged my mafs and couldnt make it throw a code
unplugged my CAS and got it to throw a 11....
could it be something with my mafs forcing it into safe mode?
sleepin240
ok another update got it to throw a code with the mafs unplugged
eh?
check your tps voltage..
sleepin240
tps reads good
sleepin240
ive determined my ecu is stuck in safe mode
sleepin240
well after reading on skylines down under i am reconsidering my safe mode theory it seems that it wont go past 3000 rpms at all mine however will rev all the way up while sitting still
Joe
i would look at trying to get another maf to test. sounds like its bad.
sleepin240
ok so i was just kiddin about that 3000 rpm at while sitting still it seems i was dreaming... i can stomp it to the floor and hold it and never get past 3000 ish
leroy0053
mass air flow sensor. definitely hands down.
