RB25/RB26 Help Please
Hound
Car: Protege5
Hey guys I am totally new here and have been going through the site picking up a lot of valuable info.....THANKS for that. NOW I have a question/request if someone could help me out. I am a tad short on RB's around the house including the trans and I am in need of some measurements. If anyone would be willing to get me a rough measurement of the overall length Engine and trans, rough height of engine and rough width of engine I would be extremely appreciative. Needing this to ensure it will fit where I am trying to fit it. Sure it will but I would like an Idea before I go to purchasing things and ending up with stuff I cant use. Thanks again for any help.
rwd measurements not awd
frapjap
'07 Subaru Legacy
Welcome to NICO!
Glad you're finding our community helpful!
I'm not really able to help you out in regards to your question, but I'll try to get you some help.
Whats the project you're starting?
Hound
Car: Protege5
Engine swap into a totally different car just looking for the specs stated to ensure the possible fitment and what I may need to adjust or look for in the swap procedure. Thanks again :)
PapaSmurf2k3
Site Admin
hmmm... we MIGHT have better luck posting this in the RB forum.
rb20-rb25-rb26-forum.html
Hound
Car: Protege5
sounds good to me. anything that helps get me some info
PapaSmurf2k3
Site Admin
You got it! I'll move the thread.
Hound
Car: Protege5
thank you
Hound
Car: Protege5
OK so sometimes I get impatient and I start looking for clues for answers to my own questions. I took the stock bore of 87mm and multiplied by 6. This gives me 516mm which was something like 20 15/64 inches. I looked at an existing engine I do have with a stock bore of 83mm and multiplied it by 4 giving me 332mm which was like 13 5/64 inches. Measured the actual length of my engine and it was roughly 19.5 inches giving me a rough 6 inch distance for cylinder walls, casting imperfections, and can pulleys timing ect.... So by a guestimate the RB25/26 should be close to 26 or 27 inches in length. Also in theory the RB25 stroke of 73.7 mm is shorter than that of my engines 91mm stroke so the rb should be somewhat shorter....should but no promises.
Now I found a pic on the net of a trans and drive shaft side by side also a pic of a drive shaft laying on a towel in close proximity to a welcome mat. People are now thinking I'm nutty.... Bathe towels are something close to 3ft in length and doormats usually 2ft. Ish..... The drive shaft was just barely overhanging the towel and laying next to the trans was longer than the trans but not a lot by my guess no more than 6 inches. Sooooo.....shaft of about 42 inches and a trans of about 36 inches. Total length of roughly 62 inches. I am assuming I am close but incorrect. However this is closer than I was. Any help is still appreciated
bmxarmy
Car: 1961 AMC Rambler
total length of an rb25 trans is approx 30"
Hound
Car: Protege5
Awesome thank you. I guess my +6, was a good measure of error in my favor. Appreciate the input
