McAdam »
https://forums.nicoclub.com/mcadam-u5096.html
Sun Jul 27, 2003 10:04 am
I have first hand experience at the RB20 install. It was actually quite easy. hell, for the $1900 it took to get the RB20DET and have it shipped to the front door, it was an excellent price! I am thinking the RB20 will handle more stock HP than the SR20. I say this because it is spreading the HP out over 6 cylinders as opposed to 4. It goes right in to the 240sx, all you have to use is the Skyline front cross member, which is 6 bolts and its in. Not a big deal.
hassles of RB20 install.
1. your tach won't work. (easily remedied with an aftermarket one)2. Your temp gauge wont work (not enough time to figure out the wires on the one I did)3. have to cut hole in engine bay to fender for IC pipes (will have to do this for ANY turbo engine)4. Wiring. it took a few hours to sort, but not that bad at all. (SR and RB25 will need wiring issues too)5. Down Pipe rubs ever so slightly on the steering shaft knuckle6. Have to use and wire in electric fans. (just a good idea on any engine if you want more HP)7. have to "trim" hood to get it to shut. otherwise, stays on first safety click.
Ease of the RB install.
1. Front clip crossmember bolter right in, motor mount problem solved. 2. drive shaft mated right up.3. used KA lower harness for starter and alternator, spliced RB plugs onto harness for transmission switches.4. transmission mount bolted straight on.5. RB downpipe to catalytic converter exhaust pipe bolted right on to the KA cat.6. engine dropped RIGHT in. fit like it was meant to be there. Email me if you need pics.7. Power Steering lines for SOHC KA had enough sslack to goto RB pump.8. AC compressor only needs a line about 3 inches longer, and it too will bolt directly on.
well, thats all I can think of. Email me if you have any questions or want to know anything about the swap.
McAdam
