rb25 randomly no spark!
lazyeyes13
Car: 1991 s13 hatch rb25det
1989 s13 hatch
2004 g35 coupe
So my s1 rb25 s13 was running very very rich, had weird idle and what not.. So I noticed that the TPS was unplugged, I plugged it in, disconnected my battery for about a minute or so, hooked it back up and hoped it would fix the weird idle problem! I tried starting it, and it just cranked, would not start...
I am getting fuel but no spark... I pulled the coils and a plug, put the plug in the coil and grounded it and cranked it and I got nothing. The plugs are fine because I just changed them 2 weeks ago and I sandblasted the one I tested. I used a test light on one of the coil connectors and Im not getting any power whatsoever.
My guess is I have a bad relay or something
Anyone had similar issue or could help????
outlaw7
Car: 78 zed
Are you getting power at the ignitor?
lazyeyes13
1989 s13 hatch
2004 g35 coupe
outlaw7 wrote:Are you getting power at the ignitor?
Havent checked yet... I will tomorrow the cars at my tech school.
If I am what could it be? and if im not?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
check your ground to the igniter and chassis ground
lazyeyes13
1989 s13 hatch
2004 g35 coupe
USMCgetsome wrote:check your ground to the igniter and chassis ground
I will check that tomorrow and update
lazyeyes13
1989 s13 hatch
2004 g35 coupe
I unplugged my igniter and the connector that plugs into has no power when the key is in the ON position. When I crank it over it gets pulses of power...
I plugged the connector back in and unplugged the connector leading to the coil pack harness, then I checked for power at the igniter in the ON position and during cranking and no power whatsoever...
Could it be a bad igniter maybe??? And where is the ground for the igniter??
Also ive heard people say it could be bad relays, like the ign relay or the eccs relay and that they are down by the ecu... I only see one and I can hear it clicking so I think thats good, and the ecu lights up when in the ON position so I assume the one I see is the eccs relay.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
getting any codes?
lazyeyes13
1989 s13 hatch
2004 g35 coupe
figured it out! the igniter lost its ground.. grounded it and it fired right up!!
Now i have another problem...
its running very rich and its idling weird... it idles fine until you give it gas, then when you take your foot off the gas, the idle gets very low almost dies...
Its almost like its loping
It sounds like its not getting enough air at idle after coming down from rpms
Anyone know what it could be???
