RB25 pulleys
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
Are the following parts the same on the RB20 as the 25 Water pump pully power steering pump with pully alternator harmonic balinceing pully the triple pully i also need to buy the timing belt cover top plate and the back plate I bought a RB25 from Jhot for 1800 dollars and the car was in a front end collision but that is cool because i am about to take it apart because they had some sort of stand alone computer on the car a 3in down pipe and a cusco raceing plate across the top so hope fully i get cams
JonPowell
Car: Cars, Music, My family
Crank pulley is a little different on Rb25 than Rb20 and the RB20 is a little wider. The RB25 has a one rib difference form the Rb20 on the outermost pulley.
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
sean8564 wrote:Are the following parts the same on the RB20 as the 25 Water pump pully power steering pump with pully alternator harmonic balinceing pully the triple pully i also need to buy the timing belt cover top plate and the back plate I bought a RB25 from Jhot for 1800 dollars and the car was in a front end collision but that is cool because i am about to take it apart because they had some sort of stand alone computer on the car a 3in down pipe and a cusco raceing plate across the top so hope fully i get cams
1800 bux, mods and hit in the front end. lets just hope it runs because it was ragged on. Never buy a modded engine espcially ones that have been hit in the front it just means the ******* who had the skyline drove like an ***. Too late now, but ya got mods
sean8564
1993 Nissan Silvia
oh I know not to buy a moded motor i bought it 4 months ago and they did not have any info on it until it was at the Shop and unloaded
Joe
Slo_240sx wrote:1800 bux, mods and hit in the front end. lets just hope it runs because it was ragged on. Never buy a modded engine espcially ones that have been hit in the front it just means the ******* who had the skyline drove like an ***. Too late now, but ya got mods
how in the hell do you figure that? my clip showed up with front end damage and a mines ecu, the engine was immaculate. absolutley no funny wear on the valvetrain, leakdown test was better than i could have hoped. my buddy got a 1jz for his cressida the engine showed up in the clip spotless, totally stock with only 3x000 miles, pulled the valve covers off and there were 2 inches of sludge because the owner never changed the oil.
its all hit or miss, there is no way to judge an engines condition by modification level.
Ramius83
Car: 1995 240sx SE
Kamin wrote:its all hit or miss, there is no way to judge an engines condition by modification level.
I agree. My RB26 came with the wastegate actuators vacuum lines cut (meaning an aftermarket boost controller was used). There were about 5 connectors on the wiring harness by the ECU, showing that some monitoring or remapping piggy-back was used. A set of HKS filters with piping was installed on the MAFs. The engine itself was dirty with dust, oil on the right side, etc....
But pulling off the old water pump showed an N1 water pump was installed, Greddy timing belt, some sort of aftermarket lower temp thermostat, NGK Iritop 7 plugs, etc.
And the leakdown test showed me A++++ results across the board. So it is a hit or a miss when it comes to buying these motors, unfortunately.
sean8564
1993 Nissan Silvia
NO AFTERMARKET CAMS I LOOKS PRTTY MUCH STOCK but i still need to find those other parts
