240sxwanted »
https://forums.nicoclub.com/240sxwanted-u169270.html
Sat Oct 02, 2010 7:14 pm
So today i replaced my old sparks on my s2 rb25det which some ngk iridium 7 that are factory pre-gapped. The ones that were replaced were the ones that originally came with the engine. They were some ngk iridium 5. The reason i replaced them is because once the engine was warm i was experiencing some bogging and power loss when i got on the gas hard, but at light throttle it rev perfectly fine, but as soon i stepped on the gas pedal all the way it bogged and it seemed to have a power loss. Its pretty much a stock rb25, mods include: isis intake manifold, stock throttle body, fmic, stock skyline radiator, stock turbo with rb20 actuator (10 psi). The turbo that is currently installed is a replacement, the original had an rb25 actuator and blew about two months ago. I can't really remember if i had this issue when i had to original turbo, i guess because i just had the swap done and didn't want to push it hard. When the rb is cold or not at temperature, it runs really good. It pulls very hard as it should. But as i stated, it seems like it bogs and loses power when he car is warm and i step on the gas all the way. Today i also taped up the coilpack boots really well along with replacing the spark plugs. After doing this I decided to take it for a drive while the engine was warm. It seems like the spark plugs helped somewhat of my problem, but it doesn't feel like im getting all the power like when the rb is cold. Could it be that I need new coilpacks?
