Coolwhip wrote:as well, if i'm not mistaken, a RB26 rotating assembly (pistons, rods, crank) in a RB25 results in pistons extruding from the block deck a few millimeters?
You can put an RB26 rotating assembly in the RB25 and it will match up perfectly. But if you put RB26 pistons on RB25/26 rods, then the pistons will sit recessed in the bores at TDC by (1.21mm if I remember right). Now putting RB25 pistons on a RB26 crank will push them out of the bores that same dimension, but who the hell would ever do that?
My original plan was to source an RB26 crank and use the RB26 rods and pistons, but I couldn't find the crank (And NO that's not what she said). Now I can get one for cheap but already have the entire engine built...Timing sucks sometimes.
Like I said before, the RB26 pistons are far superior to the RB25's and I happen to have find a set in my basement that is now for sale for $150. LOL shameless plug.
