RB25 parts/swap list, hows it look?
sausagelinks98
Car: none
I want to swap in an RB25 into my s14 and I want you to check out my parts/swap list and tell me what you think. I am going to keep the stock cams, turbo and injectors. My goal is to hit low 13's and if possible high 12's. I want to build basically a rly fun car to drive and this will be a daily driver. I put questions next to some parts do if you can help answer them it would be great. Thanks.
RB25DET (motor set)R33 crossmember Precision turbo FMIC Custom intercooler pipingCustom intake pipingApexi intakeSyko motor sports motor mountsNismo transmission mountsSyko Custom driveshaftBlitz DD BOV Syko 3” Downpipe/ O2 housingTest pipe Apexi N1 exhaustFlex-A-Lite FansWalbro 255 Fuel PumpNismo FPR Steel braided turbo lines Blitz BCKoyo/Fluidyne Radiator (which one?)C’s short shifterACT street/strip clutchSS clutch lineLS Automotive Tach gaugeOil catch canOil cooler (do I need one and if so, can u recommend a brand?)
Replacement parts-Power Enterprise Timing BeltOEM water pumpOEM oil PumpPower super V-beltZ32 fuel filterK&N oil filterNismo thermostatFull rebuild gasket kitDenso spark plugs (hr-6)
I was told I will not need an S-AFC as of now so one it not included.
Modified by sausagelinks98 at 10:40 AM 3/4/2007
sausagelinks98
Car: none
Deatschwerks has some 450cc injectors for the RB25, how do you think those would go with this setup?
lucky7
Car: 97 RB25 S14
i have a question. where are you getting a C's short shifter?
sausagelinks98
Car: none
From nengun.com
Anyone on the parts list?
sausagelinks98
Car: none
Thanks, I'll look into that.Hows the list look at as whole and what do you think if I added 450cc injectors?
lucky7
Car: 97 RB25 S14
sausagelinks98 wrote:From nengun.com
they've been out of stock for over a year now. curious because ive been trying to find one myself for a reasonable price. all ive found was a place in the UK that has them. they want $400 shipped though...
sausagelinks98
Car: none
wow, um, nvm then. I will probably strike that off the list.
s14kouki
Car: 1998 240SX SE
Your list looks good, here are a few changes i suggest:
HKS BOV, blitz leaks at idle (as do most push type), or you can try that new synapse BOV
Test Pipe you really dont need because on S14s the cat is on the downpipe. The thing that looks like a cat under the car is actually a hollow 2.5 inch test pipe. You will see this when you get under the car. I personally use a high flow cat becuase the gas smell was that bad.
Koyo has heat soaked and crack on people using it with RBs i suggest the fluidyne or griffin if you can get your hands on one.
Clutch i recommend exedy or ATS, i never was a big fan of act, but they still make great clutches
You can adjust the tach by yourself pretty easily, just take the cluster apart and adjust it with a philips screwdriver, you can contact Syko performance if you need more help, they helped me with it. You will need something to read the actually rpm as reference though. Doesnt take too long and it saves you $100 from LS auto.
Oil cooler - i dunno setrab? haha expensive parts there. just get good lines and fittings, the core brand isnt that big of a deal.
I personally have a N1 water pump, might as well upgrade if youre going in there.
Oil pump i wouldnt know what to say, just that the N1 oil pump is dam expensive.
I also bought a gasket rebuild kit, but im too lazy to put it to use haha. I might be doing a RB26 soon enough so i might just sell it.
I always use nissan oil filters, again just my perference.
everything else on your list looks good, feel free to contact me for any questions you have about the swap. I'll do my best to help a fellow rb owner
sausagelinks98
Car: none
thanks, what do you think as of the 450cc injectors?
Bwana
Car: Denali
If you change the injectors then you WILL need either a ECU tune or a piggyback to compensate.
Sil240
Car: Nissan S13 "The One Cam Wonder"
if your using stock turbo, leave the injectors alone.
"Steel braided turbo lines"
You don't need those, unless you just want it to look pretty.
Definetly put the gasket kit on your list too.
Oil cooler is not a must, but it is nice.If your not going to track your car and its just a DD. not really necessary. But still nice though.
sausagelinks98
Car: none
I wanted the injectors to be able to push it a little more and have a easier chance of hitting 12's. I would use an S-AFC if I got the injectors. But yes, the turbo will be stock.
Sil240
Quick question??
I don't know.But...
Have you calculated if you need them???
Do you know how much air the turbo will push?Will it over power your stock injectors??
How much HP will you need to get into the 12's?
eh?
You can buy my HKS manifold!
sausagelinks98
Car: none
well I'm assuming the stock ones will be running high on there duty cycle so I think 450's will let me push the motor a little farther.
sausagelinks98
Car: none
well forget about the s-afc and injectors. I'll do everything else first, the stock ecu should be fine for that and I can always upgrade later.
Sil240
Just put the motor in STOCK, other than Clutch and FLywheel and other preventative stuff.
So that there is less to trouble shoot after its in.
