HPF Chrisk »
https://forums.nicoclub.com/hpf-chrisk-u62886.html
Tue Oct 28, 2008 1:11 pm
Hey guys i have a s1 rb25 swap in to my s13 and here are the following mods, cx racing intercooler, syko dump pipe, megan 3 inch down pipe, 5zigen 3 inch cat back, lightened flywheel and 6 puck clutch.
Before i put my fmic on i had all the same mods and was running boost of the wastegate accuator and was running 5.5psi. The car ran good and did 217whp
Now with the fmic on the car is running 7-9 psi. It will hold 7 psi for a while then on the top end it will go to 9 psi and stick. I dont have a problem with this i just want to know why it is doing this cause nothing has changed but the fmic. WIth the extra boost and fmic i dynoed it and it did 262whp is this about the norm for cars with the same mods? What is causing the overboositing? i have checked for boost leaks and there appears to be none at this time
