rb25 on zx 1985
A home for 1983–1989 300ZX owners!
neetics62
Car: ZX300
HI Guys
i have a zx300 1985 and i want to fix an rb25 with a turbo charger on it, i have many Q's about that because i haven't try this project before, i want to know is there gona be any problems in fixing the rb25 on this body and would the intercooler fitx properly or not? second thing is that because i will fix a turbo so i want to know what are the parts i need to have 400-500 hp and i want the engine in the safe side, i need more informations from u guys
thanks...
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Moved to classic Z.
CerberuSlol
Car: 1987 right hand drive 200zr with an rb25det around 450hp to the wheels
So I didn't do the swap myself. Charles Plumb of Plumb Performance in east county san diego did. Although I can tell you it can fit it's a little snug for the radiator intercooler should be able to do a v mount.The intake and the filter is kinda fitted underneath than on top. It's do able though you can achieve those numbers with like a gt30r or 35r and a proper nistune or jim wolf tune. Although from talking with many people wouldn't take a stock rb25 past 450hp. I've learned from talking to others with the rb25 engines that since were not rolling in some honda want a strong turbo that spools quicker in the lower rpms. Friend made the mistake of just wasting 1700 on a big turbo that spools around 5 to 7. Heres some pics of my swap. Once again i am not a professional I can just tell you from going from an rb20det to an rb25det what my experience has been with the z31. Hopefully you'll get some responses by some of the other people on this forum like the one dude with the sick rb26 240z
neetics62
Car: ZX300
am thinking of netics t64 its not small and not big
neetics62
Car: ZX300
the intercooler pipes that in the pics 2.5'' ? and wat brand is the intercooler ? also i want to know should i change the oil pump if i want for 400-500 hp because i heared that there is a problem with the rb's oil pumps
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
For your power gioals, You'll need a larger than stock Fuel pump, 50 lb/min or larger injectors, a large efficient intercdooler (the one CerberuSlol has in a dual pass which is not very efficient and will not support the kind of power you want to make, you'll want a single pass crossflow or vertical flow, the vertical flow tends to be the most efficient, I like treadstone for price andquality),2-2.5 hot side piping ( I like to match the turbo outlet) 3" cold side piping ( I try matching this to the TB)
The higher your peak HP number the later the spool and the peakier the power band will be, Propper Turbo selection can maximize your peak while minimazing the amount of lag, keep in mind that when making 500 hp form 2.5 liters you will have more lag than making it from a 3 liter engine
a
Return to “300ZX (Z31) Forum”
