I have a S2 RB25DET that I'm pulling apart and noticed that some of the parts weren't standard, like it had an N1 water pump. So I was investigating the oil pump and I noticed a few disparities. It's stamped NISSAN on the front left like any other nissan pump, and looks like a standard OEM pump. But the bottom is a little different. Every picture I can find of the oem, n1 and / or nismo oil pumps all have a smooth bottom with an oval shaped hole in the middle, like these
oem standard
n-1
However, mine has a slightly raised rectangle with a plug. Looks like its part of the case, not added after the fact.
Also the bolt hanging off the bottom on the standard pump seems to be mounted flush while the n-1 has it projected, but mine has the projected bolt, but has the backplate screw placement of the standard pump. So I'm really not sure what pump this is. Is it an old version, or a differernt version, or a common variation, or what? Thx for any insight
