gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Wed Aug 27, 2008 10:54 am
confirm. it's female 1/8 bspt. it is close to 1/8 npt but smaller. if you try to tighten a 1/8 npt male fitting in, it may not seal correctly because it is too tight.
what gauge are you planning to get? greddy, hks, defi, and other jap gauges are 1/8 bspt senders.
autometer, stri, etc. are 1/8 npt. if you want to run a 1/8 npt sender in there, take a 1/8 bspt die and cut your sender down a bit with the die, then install.
