rb25 oil pan pickup? plus another rb26 with rb25 oil pan question
002-M-P
Car: Z33-RB26 IP
Does anyone know where I might be able to get the oil pan pickup for my rb25 oil pan because the rb26 oil pan pickup doesn't work. I have been looking around for some time now with no luck.
Also, there are baffles mounted to the rb26 crank endcap cradle for the rb26 oil pan, while the rb25 oil pan has the baffles built in and won't clear the baffles on the rb26 motor. Do you guys that have done the rb26 swap with rb25 oil pan just use the rb25 oil pan baffles and completely remove the rb26 baffles? If not what is generally done?
minivan_don
FAST-DATSUN
The RB25 oil pick up will not work as the 25 is in a different location on the block. You must use the 26 and mod the 25 pan some to allow it to fit......
NOT_A_KA
Car: 97 240sx
I bought this oil pickup and it does not fit the RB25det with a front sump oil pan. The pickup on this link is for a rear sump oil pan for the 240Z conversion.
Part number for the front sump oil strainer \ pickup is 15050-42L00
