gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Sat Nov 13, 2004 7:13 am
an update on fitting the 25 pan to the 26 block:
the original holes that are for the 26 pan do NOT line up with the 25 pan. However, there is an "inner" set of holes which do line up with the 25 pan. The "inner" holes on the intake side, however, are partially filled and they will need to be drilled out/threaded to fit some new bolts. also, the oil pickup sucker connection is very close to the edge, and MAY not fit b/c the 25 pan will have to use the inner holes.
I'm curious to see some pics or a detailed description of how this will eventually work. Please help!! Mack @ Mckinney? Hopefully we can generate a well publicized solution to this... I'd be glad to do a write up/step by step instructions w/ photos if I could get a tried and true method. Thanks in advance all.
