s14 2510’s wrote:first of all dont use the rb25 pan on a rb26. The sumps are on different sides of the pans. In order to make the rb25 pan work you will need to cut the baffling out of the pan. Just use the rb26 oil pan and cut the diff off it. search we have dicussed this tons.
not true. the sumps are on the same side of the pan (front). i think you mean baffling? both 26 and 25 pans need work to fit into the S chassis, so its really up to you what you want to use. there are pros and cons to both. i will name a few
25 pros: lighter, cheap to replace, basic tools - dremel/hammer/shears is all you really need to mod it.26 pros: free cuz it comes with your motor but hard to replace if you mess it up, arguably better baffling, more capacity, better cooling maybe cuz of the fins.25 cons: need to cut the pickup area, need to delete the under cradle baffling, lose a few bolts that support the transmission, more prone to leaks cuz of the nature of the mods you need to do and the pan is flimsier.26 cons: high G oil starve problem still not solved (in fact may be worse than 25 cuz it has the side slosh areas, but that is just speculation on my part. i never really see rb25's oil starve as much as 26's.. again debatable), bulkier/heavier, need real tools and welder to modify vs. 25 pan, can't use sway bar anymore
