Rb25 oil feed/ drain set up pic request!!!
SlowKoop
Car: 350z s13 coupe
As the title states I'm requesting oil feed setup pics and info about differnt oil setups. The more info the better im doing this because i keep blowing seals in turbos, and want to make my lines stainless. Btw the turbo im running is a holset hx35 which looks like I need another one.
GSDKinked
Car: 1997 240SX LE
or just have it rebuilt.
SlowKoop
Car: 350z s13 coupe
Ok i could have it rebuilt but I would still like to get some info on what kind of oil feed people are running and there drains aswell.
jrd450r
Car: 1990 RB25DET S13
I am running the stock drain and a -6an feed line (EARLS) with a restrictor that's sold on eBay for journal bearing turbos, its marketed for a DSM but its the same thing. Also about rebuilding the holset, its really easy, D/L the manual from their website and read it then get the kit and do it. I got my kit from Penn Diesel for around $80 and its a genuine holset kit not a knock off. Just make sure to line everything up with scribe marks and don't bend the exhaust seal ring (I bent it trying to get it in and it sucks becuase its like a 3 dollar part that no one stocks)
SlowKoop
Car: 350z s13 coupe
Thanks that's the stuff I'm looking for, for rebuilding I don't want to rebuild it cause its not a real holset I found out after I bought it. I was waiting for it to blow to buy a real one. But now I wanna see what most of the rb community is running so I don't blow the next one.
Carl H
chances are its not blown but being over oiled.
what size feed line are you running to the turbo?
im willing to bet it needs a restirctor.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I second that. Thanks again for your help on sizing mine Carl. Previously, mine would smoke a little while sitting at a stop light. It has been running flawlessly since. :cool:
SlowKoop
Car: 350z s13 coupe
i think its dont theres oil coming out the front and i look like the misqueto man coming down the street I believe it -4an but i could be wrong. ive ordered the 4an fitting from rawbrokerage, with the 10 an drain today and pieced together lines and fittings from summit.
