kevwa »
https://forums.nicoclub.com/kevwa-u75921.html
Mon Sep 29, 2008 5:52 pm
you are correct on testing the voltage - im not sure what you should get for voltage - you can try searching on the forum or just test all of the wires and see if they are all about the same, if they are that would make me think they are alright, i mean they should all be the same, so if 1 of them is way different i would think that would be your problem - and yes it will be a pulsating voltage - actually i remember testing my ignitor a while back and i think the voltages are very small -
thats cool you have another ECU, but i would def recomend not switching that out untill you know for sure the one thats in there is not good, adding another variable to the problem by switching the ECU can cause more problems than its worth.
