Indeed it is......I just happen to know a couple guys on here have done the swaps very successfully and initially speaking I just want to confirm some things i already believe are true/false. Whiten up the grey areas a bit.
Thus far I know
Series 2 rb25 MAF is the same as NeoRB25 Gasket set works for the most partRegular RB25 Exhaust Mani will work fine when the time comes to change up the snailQ45 or something similar TB gasket should workTiming Belt,Tensioner and Water Pump on the neo is the same as the RB25CAS is the same as R34 RB26DETTAnd the wiring I'm not doingOil Pump is the sameSplitfire makes coilsAlot of clutch companies make clutches
I say this is enough info to start a sucessful swap.The rest I should be able to bumble around/research on SA or some other similar forum Nico..
But feel free to continue compiling in here if you like I sure will.
