I NEED SOME HELP!!! RB25 NEO
I had the standard hesistation issue from hot coil packs etc, so i took off my covers and insulated the bottom boots and put in new spark plugs...it had autolites...i put these in NGK BKR6EIX-11. Put back together, and it ran good. Drive to work and i noticed my gas was low...and then it dies....wont start. At this point i put gas in, still no start. Fuel pump sock was black, and fuel filter was dirty too. I noticed the fuel filter was on the return so i corrected that too. After a tow home today i took apart fuel rail and injectors TOOK FOREVER....i cleaned it all and cleaned injector screens....put back together and still nothing. I am stumped....i did nothing to cause this and have cleaned everything that could have been clogged. Could my sock be doing this to me? Any input would be amazing. Thanks!
