blah! I love the NEO. In this case it's just a wild call for a part that usually is replaced with a clutch upgrade, just a sticky situation.sepulchralx wrote:Another reason why I have always hated NEOs.
yeah man, i did a cross reference using "ALL DATA" program for technicians and found that an 04' pathfinder 2wd 3.5L (VQ35) has the wedge collar in the picture of the exploded view on the clutch setup. however, i took this to the dealer and they had a totally different pic on their computerCoolwhip wrote:
However, OP whats this talk of you finding a x-ref part for that with the Pathfinder?
The transmission was not removed by me, but by a shop my car is at. the piece is no longer usable, or else i would not be looking for a replacement. Im not sure if it comes with the pressure plate, as i cant locate a diagram anywhere. I ordered a release bearing from the dealership meant for a pathfinder which i thought was a pull type trans, and it didnt come with the wedge collar. I may be looking at a replacement clutch from exedy if i cant find this piece, or at least a new pressure plate from them.S14-NEO wrote:im going to ask this question that hasnt been asked yet...why do you need one of these collars..they are reusable,(unless you didnt know how to get the transmission off and ended up prying it off....there is a real simple way of releasing that thing when the transmission is still attached. all you need is a long screwdriver (flatblade) and release the locking mechanism from the pressure plate fingers.
DUDE yes. i would love a wedge collar! please let me know!!!Coolwhip wrote:if you still need the wedge collar I got you covered.
In the future an easier way to remove the transmission from the NEO is to take off the slave cylinder, then remove the fork boot on the right side of the trans, reach in with needle nose pliers, pull the clip pin that holds the fork pivot and let the pivot pin drop into the bell housing. Pull the fork off the throwout bearing and let it drop in the bell housing too. Then the transmission will pull right off without damaging anything.S14-NEO wrote:(unless you didnt know how to get the transmission off and ended up prying it off....there is a real simple way of releasing that thing when the transmission is still attached. all you need is a long screwdriver (flatblade) and release the locking mechanism from the pressure plate fingers.
Awesome thanks guys. ill have to let my shop know the next time they are working on an R34 neo! I actually found an RX7 FD wedge collar on ebay for $5 and got it the other day. it snapped right into place! looks like its going to work great. thanks a lot guys.Impulse_240 wrote:Some of the 2x2 pathfinders don't have the heavy duty clutch but the 2002 4x4 v6 should be the exact same clutch as the NEO.
