RB25 - Need some dimentions
dcrusupra
Car: 1988 Toyota Supra, 2001 Hyundai Tiburon, 1993 Nissan 240sx vert, 2008 Honda CBR600
I need the length and width of the RB25 at the widest part width wise, and the longest part of it length wise. I might be doing kind of an odd swap. Just want to see if it fits. Thanks.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I don't have one to measure right now, but what are you sticking it in? Also if measured clarify with or without the intake and exhaust manifold etc.
dcrusupra
Intake manifold to end of turbo, and from the pulleys to the rear of the block. I wanted to swap it into my friends '92 Jeep Cherokee. It may seem kind of an odd swap, but it came up as a joke and I want to see if we can do it. It has the straight 6 so it cant be that far off from the RB with the dimensions.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
D:
lol, i should've read this earlier, i dropped and pulled my motor earlier this evening in about 45 minutes for test fitting on a new radiator setup.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Very rough dimensions, I over estimated a little, but here you go:L x W x H
80 cm x 76 cm x 67.5 cm
(I had to estimate since my block is on a stand and the oil-pan is off as well. But with these dimensions, you should be able to see if it will fit inside them.)
HTH
*edit*accidentally wrote mm instead of cm. My Bad.
Modified by l0nestar at 2:43 PM 2/21/2007
Sil240
Car: Nissan S13 "The One Cam Wonder"
Bro how can those dimensions be right???
The RB25 piston are like 85 or 86mm
Haha the motor is a small box that is smaller than the piston inside. lol
l0nestar
2004 Toyota Altezza
My bad. I updated it. I meant CM instead of MM. Heh, off by power of 10.
dcrusupra
Excellent. Thanks. I'll let you all know how the measurements go.
Sil240
l0nestar wrote:My bad. I updated it. I meant CM instead of MM. Heh, off by power of 10.
Actually.... if i could get a mini RB I have a R32 model that needs some mini boost. LOL
