RB25 N60 issues
rb240sx
Car: 1995 RB25 240sx / 2001 Eclipse GT
I have an Rb25 series 1 with an N60 maf. I have a SAFC2 set at 2 in and 4 out with the cal set at 2 and add.
I am getting continuity between all wires to their respected locations so I know it is not a wiring issue...but...the car is throwing a code 12 and code 41. It also will not rev past 2500rpm but otherwise runs fine.
any idea's?
rb240sx
anyone?
platez808
Car: 1989 Nissan 240SX
just for clarification but is that the maxima maf?
rb240sx
Yes, The N60 is the purple labeled Maxima MAF.
I am picking up an N62 (Z32) MAF today.
rb240sx
I put an N62 MAF into the car and still the same issue. It will not rev past 2500 and I'm still getting a code 12 and 41.
platez808
are you positive you wired in the maf plug and the safc connections correctly?
julio
Car: RB26 AWD converted S14
platez808 wrote:are you positive you wired in the maf plug and the safc connections correctly?
+1....When the car doesn't rev about 2,500rpms (limp mode), that means the maf isn't connected properly in one way or another.
rb240sx
Yea, I'm 100% positive. I ran a totally new set of wires just to make sure and bypass the original wiring and still the same issue. Even with the SAFC bypassed, the ecu still throws a code 12 and 41.
rb240sx
The SAFC reads the proper voltage and everything, I even have the proper voltage at the ecu but it still throws the code
what is a code 41? air temp sensor? I thought rb25 did not have one...
well, I just found out that I have an RB26 ecu in the car...now wtf do I do?..lol... my ecu reads BV / 23710 - 05v62 / MEC - r282 / A1 / 3705
RustspecS13
Car: '74 260z and '88 300zx turbo
Well you need a RB25 ecu or a NA Z32/j30 ecu with nistune, or a twinturbo Z32 ecu- its close to working as is but should get a tune as well.
An Rb26 ecu doesn't have VTC, but does expect to see 2 mafs. Hence why it was cutting out. I didn't think it would run with a rb26 ecu on a rb25 harness....
~Alex
rb240sx
RustspecS13 wrote:Well you need a RB25 ecu or a NA Z32/j30 ecu with nistune, or a twinturbo Z32 ecu- its close to working as is but should get a tune as well.
~Alex
Yep, your right, the ecu does not have VTC but...anything can be done with a little bit of know how. I am using an SAFC with a z32 MAF set and 2 in 3 out with the cal set at 1 and 1. The car runs fine but it still doesn't run perfectly...it is still looking for the intake temp sensor and I'm quite sure that is why it's still running a little rough.
I'm not driving the car hard until I have the right ecu for it. Right now it drives, boosts and everything with the 26 ecu just the idle is funky.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
You need either an RB25DET ECU (for direct plug-and-play) , or either Nistune or an emulator board with a Z32 (VG30DE or DETT) or J30 ECU.
